Ignition battery charger for the Fuji 50 EI
CA
Hello everyone,
I am wondering just how to setup the battery charger for the electronic ignition battery. Do I connect battery to charger, then charger to ignition? Will charging the battery effect the ignition? What is the correct battery for the ignition? The engine I've installed is the Fuji 50EI. Thanks in advance for any help.
Carver
Carver
![](/forum/images/badges/premium_vendor.png)
We use a 4-cell NiCd or NiMH battery pack of about 500-700 mAH. You just unplug the back from the ignition system and put it onto a regular charger. The receiver-side charger that came with your R/C system will do a nice job, as will many other chargers intended for charging receiver battery packs.
