Gas Tank....???
RE: Gas Tank....???
With the tank mounted to the test stand/table I have seen the tank vibrate enough to introduce bubbles into the fuel line and vary the engine speed enough to shut the engine down. Yes I would use foam.
Bill
Bill
My Feedback: (16)
GA
RE: Gas Tank....???
I would recommend that you use foam to seperate the tank from the airframe.
WHile you may not have a problem, is your plane worth the $4 in foam for the tank, battery and receiver.
