Micro pulse fuel pump
ON, CANADA
Hi Everyone I am trying to locate this fuel pump. It is used on a large scale r/c gas boat the motor is a 37 cc 2 stroke water cooled marine gas engine with a simple slide barrel carb from Kiehin. The pump is 1.25" in dia and .5'' high and the INSIDE dia of the nipples are 1/16" in dia. The motor/pump came from Japan the company was KNK r/c boat models back in the mid 80's Tower Hobbies was carrying this stuff. I would like to know if anyone has ever seen this pulse pump and where I can get one. KNK is still in business but they longer use this pump since they are using the zenoah's for there models. If I cant' locate this pump what is out there that would be similiar in size I checked into Walbro, Mikuni, and Kiehin and they are trying to help me out also.
Regards
Regards
RE: Micro pulse fuel pump
I know nothing about boats but I do know that Perry makes some compact pumps that will handle gasoline and support flows for all the common gasser style engines. Perhaps this would be the solution for you.
[link=http://www.perrypumps.com/prod02.htm]Perry Pumps link[/link]
ON, CANADA
Mr. Raven thanks for the reply greatly appreciated, I called them and yes they do have a pump that will work just fine. Thanks for the link, now I can keep on boating!
Regards
Regards
