Low end adjustment on new Fuji 43EI
I am still running the first gallon of fuel through the engine. It is at 50:1 ratio as indicated in the manual. If the low end is not a steady rpm, kind of a broken not steady rpm, does that show too lean or too rich. Should I leave it alone until the first gallon is finished and I go to the 100:1 ratio?
Frank
Frank
