question about stand off mounts
OK
Does anyone make a standoff that is about 3 inches long? I need stand offs that are about 3 inches long to make my prop clear the cowl. If anyone make them where can I get them?
RE: question about stand off mounts
Here is a link that you can get custom made standoffs any length same price. Cheaper than DL http://forgues-research.com/
When you open this up, look on the left for products and click on that, then scroll down until you get to standoffs. Remember he is showing the price in Canadian Dollarsexchange rate is about 1.80 to 1.00 in your favor.
Gene
Gene
Mine came with standoffs, but two short. They were 1 3/4" and I needed 3". Tried the 3/4 sq hardwood but didn't have enough room to clear the cowl.
TX
ORIGINAL: millertym2000
can I use plywood and cut it into squares and put them together to make the standoffs
CR
I agree with CR. You use too long of standoffs (3") on any gas engine bigger then a 26cc it is going to shake the plane to pieces. I cut 1/2 or 3/4" plywood in a circle to match the engine mounts and run long bolts through that. You can cut the center out of the circle if you need to get to the carb or fuel lines.
Or drill a hole through 1" dowels like CR said. Lots better. Those big gas engines have lots of twist when they run.
