New .90 gas engine (15cc)
#176
AZ
[8D]I have a bunch of plans in stock for .90 size RC models so I just ordered one of these engines.
I am just finishing up with a plan built 140" Ugly Stick with a 3W-150 and it will be nice to work on something not so unwieldy for a while.
#177
I got my JBA J15G about a week ago. Have about 45 minutes of break in time on a test stand @ 20:1 and a 13x8 prop.
Thought I'd mount it up in my TopFlite P-51 60 ARF. Here are some photos:
#180
FOOPED,
I'm using the stock TopFlite mount. This engine fits the plane really good, the muffler hangs out about 3/4" and the cowl will have to be trimmed about 2mm at the intake for the carb. I'm going to finish the break in and final adjusting in the plane.
Can't wait to see how it handles in the air...
Should be some great zoom zoom AJ [8D]
#182
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (7)
IN
brockettman ,
That little gassers looks cute as a button in that plane!
Two questions though;
Can the exhaust pipe be rotated around (anywhere you like), or is it stuck in one direction?
Will you have enough airflow over the cyl head (with cowl in place) to cool it?
#184
ORIGINAL: erieqc
The exhaust pipe is like a glow engine one it can be rotated anywhere you want.
They come sealed with a very strong anaerobic sealant. You must heat a lot, clean , and apply sealant again...
Regards
#185
IN
Hey regets ama - Have you tried a three blade prop? I am going to build a 108 inch PBY this winter and want to use two of the JBA J15G. However, a 12 inch prop is the lafgest that will clear the fuselage. I am thinking a 3-blade 12 X 7 or 8 might work. What do you think?
#186
a1pcfixer,
I haven't tried to rotate the muffler. It is a two piece design, so I guess if you loosened up the back half you could rotate it.
As far as cooling, the carb blocks much of the air inlet, so I have been pondering a possible solution for more air flow over the engine.
#187
IN
Here is a video of my ucando 40 size with the 15 gasser and a 15x4 prozinger prop. i'll need to move my cg back some to get a good hover,,,,,,,,but you can see the power
[youtube]http://www.youtube.com/watch?v=tl9gtl5gaq8[/youtube]
#190
ORIGINAL: regets ama
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#191
ORIGINAL: erieqc
mpascual what kind of sealant do you recomend because I have to rotate mine as you can see in an earlier post of my Aeroworks 300.
Thanks Bill
Thanks Bill
#193
IN
someone wanted some photos of the jba in the ucando cowling, as attached.
not that i was in a hurry, but i tend to go toward function rather than form and i really believe in MORE cooling so i dont fuss too much with fancy cowl cutting.
i enjoy the xfc every year in muncie at the ama and you really get to see form and function, those guys/gals do a really nice clean job with thier airframes.
#195
ORIGINAL: mpascual
Regards
ORIGINAL: erieqc
Regards
#198
ORIGINAL: airborne2.4
For those us that are on the pre order list will have our motor in hand by next week Jody?[
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
I know JBA is making new batch of this engine model. Here in Europe they are sold a lot.
Regards
#199
ORIGINAL: mpascual
Is the engine out of stock ?
Regards
Regards
http://www.valleyviewrc.com/Gas%20Engines.htm
I'm kinda guessing with the question. I can't wait to get it strapped to my AW 46-60 Edge 540T.
