Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Pica 1/5 T28 Engine Ideas
Old 01-13-2003, 07:51 AM
Hircflyer's Avatar
Default Pica 1/5 T28 Engine Ideas
Looking for suggestions.... I'm considering Z23, RCS 180, OS 120 4 cycle....
Anyone with experience with this kit I would appreciate your ideas.
Old 01-13-2003, 01:15 PM
My Feedback: (33)
Default T-28 G/S engines
I have built 2 of these. One wutha ST300 and one with a Z23. The 3000 had plenty of power but it never idled well. The Z23 ran well but was a little low on power. Needed a long take off run even with flaps. If I was to do another I would use a Fuji 32. I am running one now in a PAC GeeBee Model Y 82 " and its great.
John N
Old 01-13-2003, 07:02 PM
My Feedback: (34)
tailskid's Avatar
I used an OS 1.08 in mine - plenty of power...
Jerry
Old 01-14-2003, 06:19 AM
Hircflyer's Avatar
I was at the field today....really nice day.....anyway had a oldtime flier suggest a Quadra 35 for this installation..
Any comments? I think it might be nose heavy any opinions?
Old 01-14-2003, 02:24 PM
My Feedback: (34)
tailskid's Avatar
You could use the extra weight up front....
Jerry
Old 01-14-2003, 06:57 PM
Hircflyer's Avatar
Thanks for the info...
Another quick question based on your experience what retracts you recommend?
I noticed there were several avialable.
Thanks again.
Old 01-14-2003, 08:15 PM
My Feedback: (34)
tailskid's Avatar
SpringAir worked for me.....but you really should get some functional struts (i.e. Robart)....
Jerry
Old 01-14-2003, 10:46 PM
Hircflyer's Avatar
Thanks again, need to start saving my Diet Coke money.
Appreciate your help.
Old 01-14-2003, 11:06 PM
G'Day Hircflier,
Like you I've just started the continuous weekends, it's great !
Maybe your T-28 is much bigger, but I used a Saito 170 R3 radial in a CMPro 70" FW-190. It was a perfect match for the model and fitted neatly inside the cowl with about 1/2 " to spare around the rocker covers.
Not cheap, but it sure looks good, and the sound ..........
Old 01-14-2003, 11:51 PM
Hircflyer's Avatar
This one is 1/5 scale weighs about 12 to 14 pounds.....but the way I build it will probably come out a couple pounds heavier.
Old 01-15-2003, 04:25 AM
My Feedback: (-1)
I have a OS 160 mounted straight up in mine, it clears the cowling ( shortest head cylinder available) and still gives you space underneath for the retracts. I used a j-teck pitts style exhaust. It required some modification like removing the exhaust stacks and making a single exhaust tube straight down. I use a three bladed graupner prop a 15 x 10 and I couldn't ask for better performance. Flies like a jet at high speeds and slows way down with flaps to a crawl. If you go with spring air make sure you use robart struts and use drill rod for your wire anything else and you will be fixing gear all the time. If I had to do it all over I would go with as heavy a robart strut I could mount.
Old 01-15-2003, 06:45 PM
Hircflyer's Avatar
Thanks for the info......I think I will go for the Robarts still looking on engine tho.....I really would like to use gas mainly for economy, I guess, we pay a lot for glow fuel. Our gas is up to 1.79 now and climbing
Old 10-19-2004, 04:39 PM
Default RE: Pica 1/5 T28 Engine Ideas
I´ve got a similar question
my t28 1/5 scale WS 2057mm = 81 inch is about 4,5kg = 10lbs covered, incl. spring air retracts but without any rc-components.
but what engine?
a supre tigre s3000 is waiting for performance a home but I think this one is much to strong and the 2s sound will not fit to this fine plane.
any ideas/experience for a got performance 4s, throwing an eye already to saito fa120 or 150 or maybe os fs120.
how about the flight performance with a 120 4s?
is there enough space for the big 4s cylinder in the hood?
theo_b
Old 10-19-2004, 09:34 PM
Theo,
I just sold my pica 1/5 scale t-28. It weighed 14# and had a YS 120 for power. The engine was marginal for power. I would recommend a Saito 150 or 180 depending on how much your plane weighs. I used Springair retracts which were originally sold with the kit. I would use solid gear struts as the wire ones bent a lot. Springaire now makes them. I have a set of Springaires in my Hanger 9 150 size P-51 and they work great.
Bob S
Old 10-20-2004, 04:45 AM
Hi Bob S
my t28´weigth is about 4,5kg = 10lbs covered, incl. spring air retracts but without any rc-components. of course dep. on engine i hope it will not be more than 6,0kg = appr. 12lbs ready for take off.
YS120 ? if you mean Yamada engine i can not compare, these are not sold here in austria. can you give some figures and performance-datas about the YS120?
what about the installation - did you have to cutout your hood?
many thanx for help
theo
Old 10-20-2004, 02:20 PM
Theo,
I believe Yamada makes the YS engine line. I feel the YS 120 is 25% more powerful than an OS 120.
I think you are going to have a hard time coming in at less than 14# with all components installed on the
T-28. I had to make a small cutout in the cowl for the front of the valve cover with the engine mounted upright.
As I said before, the 120 wasn't enough power. Try something bigger. With the YS 120 the plane would struggle to takeoff, but once in the air it flew beautifully. I liked the way it flew, but not the takeoff. Mine was the yellow version as seen on a 3view with the kit.
Bob S
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
