h9 taylorcraft HELP!
IM IN NEED of some help i have a quadra 42 i think it might be to big i also have a g23 i think it might be to small does anybody have ideas on a motor for this.
also i have some 425bb hitecs 4 each
and 1 525bb will these work and which one should i put the 525 on
chris
chris
My Feedback: (17)
TX
On "Torque Reform"....
Put the G23 in it. The Quadra is too much. You definitely want a high torque (100 oz. +) servo with a strong gear train for the elevator and rudder. For ailerons, I would think a 50 oz. + torque servo will be fine.
My Feedback: (18)
Chris,
I have one with a G-38 on it and it is perfect. I have seen one with a G-23 and it seemed a little under-powered for my liking. Mine balanced perfect and weighed 14.75 pounds. If the Q-42 is not much heavier than the 38, I would put it in there.
As far as servos, I went with Hitec 605's on elevator, rudder, and ailerons. You do need more than standards, especially on rudder and elevator, standards may be OK on the ailerons but I wouldn't chance it.
Hope this helps,
Alan
Hope this helps,
Alan
My Feedback: (7)
TX
I almost agree with Bama. If you don't mind cutting the crap out of the bottom of the cowl, stuff the quadra in it. I have one with the new G26 and power is good, but still don't have that safety net to get out of bad situations.
I also ran HiTec 605's on everything but yhr rudder. There I used metal geared 645.
If you think about Hitec servos, Do a search on here. I have problems with them centering in the same spot and this seems to be a common problem with them.
The TCraft is a great sunday flyer. Also do a search for Talorcraft and find some of the mods done to help its dependability.
My Feedback: (24)
I have a Saito 1.50 in my Taylorcraft, and I'd say it is adequate. It's definitely not overpowered, but it does most aerobatics with reasonable vertical performance, while allowing normal cruising around at a little more than 1/2 throttle. The one problem with it is that it required 20oz. in the nose to balance, so a heavier engine definitely wouldn't hurt.
I also have regular Hitec 605's all around in mine, and find they work just fine.
