Futaba 7C 2.4 FAAST For 30% Planes
CA
RE: Futaba 7C 2.4 FAAST For 30% Planes
http://www3.towerhobbies.com/cgi-bin...?&I=LXARP3&P=M Only for Hitech digitals as they are programable.
My Feedback: (42)
ORIGINAL: ledsled
How do you reprogram the Hitec servos to have one reversed? I use the Futaba a servo reverser, but if I can keep it simpler I would.
My Feedback: (15)
NJ
I think Futaba has thrown us a curve ball, on the 8UA & 9C channel 8 is pre-programmed for ailevator & 2d elevator, channel 7 on the 7C did not work well as the 2d elevator, no trim function, have to do it mechanically. I found out that channel 5 is what works for 2d elevator, you have to disable the switch functions(null) so channel 5 operates normally, not like a gear channel. Its working great in a Chip Hyde Double Vision, have channel 7 as an extra channel. Im pretty sure Futaba is saying channel 7 is for 2d elevator, but thats not the case.
