glow Plug seals /copper washers
ND
Hi can anyone tell me where i can get the copper washer seals for glowplugs ! I one time had a part number for them but since had lost the number ! hope to hear from someone on this ! Thanks RB
My Feedback: (102)
RE: glow Plug seals /copper washers
I too re-use them, my favorites are Fox and H9 because they are thicker and fit the glow plugs more precisely, some cheaper plugs come with gaskets that are too thin and the holes are too big and fit sloppily.
ND
I have been reuseing them also only because I dont have new ones ! reusing a copper ring gasket has always been a no no in the automotive world ! i hate reinstalling them but always do and I know that someware there has to be a place to buy them ! I sent a email to OS i hope they can tell me ! if i find some I will post the info ! thanks Guys
OK
You might have better luck contacting Charles Thacker at Fox to see if they would sell them. Fox is one of the (last time I heard) 4 US manufacturers of glow plugs. They have always been pretty accomodating to me - but I never asked for glow plug washers.
Worth a try...
Dan
Worth a try...
Dan
My Feedback: (37)
MI
Copper gaskets may be re-used if properly annealed (softened). If the gasket is in good condition there should not be a problem. I have done it on cycle engines, cart engines, and glow engines for years with no problems. If it is copper you can re-use it. Annealing will take the "work hardness"(caused from being under pressure) out of the gasket by heating it and allowing it to cool slowly. Once soft again it is no different than a new gasket. There is a much more scientific approach to annealing, but I was taught by an old pro with a propane torch track side while dirt bike racing. Now I use the kitchen stove and a wire to hold the gasket over the flame until it glows dull red then slowly reduce the heat source. As long as you do not dip into liquid (quench) or blow on it (quench) to cool it the softness should remain.
This is my method of saving a few dollars and a lot of time....works for me.
ND
just talked to Tanya at fox and they have them for a dime each ! I know that most of the time they can be reused with no problems ! but i like to remove my plugs and prelube befor storing and also i have been checking compression on all of my engines just to watch their differances . I had one plug seal that was leaking at the seal and evenn after I retightend it ! I didnt want to just garilla the plug so a new seal was installed ! now I have a plug minus a seal in my flight box! anyway all is well i ordered a couple doz im sure it should be a lifetime supply LOL thanks for everyones info !
