Saito 82 oil leak
Saito 82 oil leak
I have recently replaced the bearings in this motor and used a sealed bearing in the front one. The problem is that there is allot of oil coming out on the front of my cowling which it never did before, any ideas or suggestions are welcome.
Thanx
Thanx
RE: Saito 82 oil leak
Hi Evansh
I dont think I have done anything to block the crankcase breather but I will check the breather to be sure.
Thanx
Thanx
Nope its exactly the same bearing, I made sure of that, in fact that was the mistake I made the first time and then had to redo it with the proper bearing.
