o.s. 91
My Feedback: (20)
OH
RE: o.s. 91
I agree with running a 2 blade prop.
The theory on that is, when the blades are spinning, each one is moving in the other one's turbulence which is most minor on a two blade. A three blade or four puts the blades that much closer together and they run in more turbulence.
I it looks cool on the ground but there is a considerable loss of thrust with each blade you add. good luck in your decision.
RE: o.s. 91
Like Minnflyer, I use a Graupner 12 X 8 on my OS 91 in a Cessna and it does Great. I had to go to it when I had floats on it and liked it so much I left it on. ENJOY !!! RED
