OS .30 surpass opinions??
My Feedback: (264)
MD
I have a new .30 surpass, I have searched this forum and not turned up much info on it. I have read opinions on other boards that the previous model, the .26 is a better running engine.
Are there any .30 surpass owners here who would like to give opinions on this model? Are you happy with it?
Thanks, Mike
Thanks, Mike
My Feedback: (264)
MD
That's what I would assume, the cam and head are the same part#. Other than displacement, the rest of the engine is pretty much the same as the .26 surp.
I do see that the exhaust is not the same as the .26, and the .30 muffler outlet is very small, even for a .30 size engine..........
![](/forum/images/badges/premium_vendor.png)
My Feedback: (102)
Dude, having two Saito .30s and judging by my OS .52 your .30 will thrive on a Graupner 10.5x5, a 10x5 will be a little light. It should be a schweet engine. The Saito .30 is a perfect engine for a Sig LT 25 like plane so will your engine be.
My Feedback: (264)
MD
Thanks hobbsy. Graupner props are a little hard to come by at the LHS, I do have a apc 10.5X4.5 that should be fairly close to the same load as your prefered prop.
From what I understand the saito is somewhat more powerful than the OS engine. If the saito .30 were still available, I would have tried one of those instead.
My Feedback: (102)
Dude, just order one or two from lobby-lobby.com, they are fast on the shipping.
http://www.hobby-lobby.com/grprop.htm
My Feedback: (42)
MA
I am running an OS FS30 in a Great Planes Sporter EP that I converted to glow. It has very good power, is very quiet, easy starting and idles great.
It is a very nice running engine
![](/forum/images/badges/premium_member.png)
My Feedback: (314)
I had one in a Modeltech Cub .25. It was an inverted installation and started right up each time I flew it. One of the easiest handling four strokes I've ever owned. Surprisingly fast.
I ran mine yesterday on the test bench, it's now basically run in. I used a MA 10 x 4 as I wanted a light load on moderate RPM. Really is a lovely sweet engine.
Do have one concern though - after running 2 x 6oz tanks of fuel containing 20% oil (15% synthetic & 5% castor) through it, I removed the backplate to check how well lubricated the bottom end/crankcase is. I was rather concerned to find it was practically bone dry in that department. And when I pulled off the cam cover plate, even drier [X(]
By comparison, my Saito 45 always has ample oil in both of those areas.
I wonder why the OS had so very little oil in the crankcase? This may sound sorta weird, but is it possible that the ring is sealing "too well" & not allowing enough blowby gases & oil to pass through to the sump area?
TX
ORIGINAL: jaka
Hi!
Well, with a 10x4 prop your engine will rew too much.
Aim for an rpm around 9000-10000. Not more.
Hi!
My Feedback: (102)
Displacement: 4.89cc (.299 cu in)
Bore: 19.5mm (.767") Stroke: 16.4mm (.648")
Power Output: .5 HP at 10,000 RPM
Weight with muffler: 10.4oz (295g)
Weight without muffler: 9.8oz (278g)
Practical RPM Range: 2,500 - 13,000 RPM
Here is the straight skinny from the OS site. I wouldn't run it over 10,000, the 10x4 is too light.
My Feedback: (14)
ORIGINAL: Hobbsy
The 10x4 Graupner runs perfectly on my OS FS-20.
Car enthusiasts are used to much shorter engine lifetimes than we airplane folks. If wearing out the engine sooner is okay, then the 10x4 is good for the .30. I tend to let my four-strokes rev up a bit anyway. So far, no swallowed valves, etc., but I don't go crazy with the practice. Just a little bit. 8>
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Ed Cregger
ORIGINAL: Hobbsy
The manual says 13,000. The crank and rod seem ample enough for much more. If the valves don't float it's OK. I doubt that the 10-4 will allow it to reve past 13,000 its only 1" less pitch than a 10x5 which lets it run about 10,000.
I flew my "Baron" with a FS30 since 2 weeks now. I have 10 tanks flights. I broke twice the exhaust valve spring, one with a 9x6 propeller after 4 tanks during the break in and the second after 4 flights with a 10x4 propeller.
I have a friend who had the same problem.
I use Power Master 10% fuel, the same for Saito 72 and 56 4 Stroke with no problem.
I wonder if any of you ever hear about this problem : i believe it is a problem with the spring itself that doesn't support well the heat in the engine ???
Thanks for your advices.
Pierre.
Pierre.
AB, CANADA
ORIGINAL: scott17
Rev too much for who? The same basic engine is used in cars at about 19000 RPM. I learned a while back that 30s like to rev a bit. Try it and see!
ORIGINAL: jaka
Hi!
Hi!
My Feedback: (16)
ORIGINAL: Milcent
Pierre.
Pierre.
Set the valve clearance .04 mm to .1 mm
My Feedback: (264)
MD
ORIGINAL: Milcent
Pierre.
Pierre.
Pierre, those are the same prop sizes that I would use in a .25 two-stroke. I think you are over revving your engine.
Mike
