OS Max-H 60 GP (rear intake) question
My Feedback: (66)
SC
I just picked one of these up, and I can't seem to find much info on it. I was planning on putting it on my Sig Somethin Extra, but one of the guys at the field says that it is a racing engine, and is designed to run flat out all the time, and therefore would not be a good choice. Is this true?
My Feedback: (66)
SC
RE: OS Max-H 60 GP (rear intake) question
Somewhat collectable....didn't realize that. Collectable enough that maybe I should choose a different engine for the SE?
My Feedback: (66)
SC
I also got a Super Tigre V .56, a Torpedo 40 rear intake, and a Fox RC 59. Any collector value on any of these?
My Feedback: (8)
Well... Ya never know what the market might bring. It's not super-rare... I see that you have the box, do you also have the paperwork?
It's probably about as powerful as a modern .46...it is more a torquer rather than a revver though. A 12x6 or 11x7 or thereabouts would be a good starting point for props, and an idle bar plug...low nitro fuel (5-10% ) with plenty of oil, some of it Castor. (should you decide to use it )
My Feedback: (8)
ORIGINAL: ScottMcM
Yep...
If you're not really into collecting...then you might consider selling them and buying some newer designs to actually use?
If that OS .60 is new in the box (never run) you will easily get enough for it to buy a brand new OS AX.46.
Your engine is ringed and will require a gallon of fuel at a rich setting to break in and you absolutely must use fuel with castor oil. If you put Cool Power through it and peak the needle on the first flight you will have ruined a true collector's item. A terrible shame.
These engines are getting harder to find. If I were you I would sell it. I don't think it's what you want in a Somethin' Extra.
David
David
My Feedback: (66)
SC
I think I'll probably sell it and buy something newer. I've already got the Fox 59, the Torpedo 40 rear exhaust, and the Super Tigre up for auction....don't have a single bid though, and was beginning to wonder if I'm wasting my time. If these sell ok, I may list the OS, an Irvine 61, and a Fox 60 rear exhaust. I really don't have much use for any of these, except maybe the Irvine...it seems more like a "normal" sport engine than any of the others.
My son has the 80 version of that H-60 and it's a delightful engine, starts first flick every time and runs beautifully on zero nitro fuel. As a sport engine it should definitely be a keeper. And I agree with Dave, keep the castor for a long (probably very long) life . Just because it's got a rear intake doesn't mean it's a racing engine, it's not, but there are two very neat things about the intake. The drum has two slots to drive it. One is marked R for reverse rotation. The second neat thing is that the carb can be turned through 180 degrees so if you mount the engine inverted you can point the carb the other way and don't have the problem of lowering the tank to suit because it effectively raises the carb back to the level it'd be when upright.
ORIGINAL: rainedave
David
David
