Revive old engines
MI
Revive old engines
I have an OS 48 Surpass and a Saito 65 both of which were put away improperly. This was some 20 years ago. Need less to say they are a bit gummed up now. I'd like to bring both back to life, as I am slowly returning to the hobby. Thinking that I can soak both in some fluid for a while to dissolve the gum, prior to trying to run some fuel through them. I'd rather not disassemble either motor, as I don't have a reassembly check sheet, or feeler gauges, for either. If I did have those items, I'd rather do just the opposite, and take them all the way down. Thing is, can't recall best solvent to use. I do have a couple of gallons of 2-stroke fuel, unopened, about the same vintage(lots of years old). I'm thinking this might just do the trick as a solvent only. Opinions or suggestions?
MI
RE: Revive old engines
Thanks w8ye. Thought the old fuel would do fine, but didn't want to cause more issues than my past errant ways have already created.
MI
Thanks. I did not intend, way back then, to just walk away, but I did, so I need to play catch up now. BTW, I opened the cases on my transmitters to see a glaring need to replace both the batteries and the connectors for the batteries. I didn't disconnect them for storage. Geez, what a lamer!!!!!!!! Then, of course, I have to clean switches and pots. All part of the fun, I guess.
w8ye is correct, suggestions are endless...
I once let two engines sit about seven years. They were gummed up tight as a drum. I'd run Omega with castor in those engines. I flushed them with Green 15% Cool Power five years ago and never looked back. I've been using 15% Cool Power exclusively with all my 2 and 4 strokes ever since. I don't use after run oil.
At the start of every flying season I open up my radio and check for corrosion, particularly on the little header pins of the circuit board where the battery connector plugs in. I started checking because one year just by total luck I happened to find those circuit board battery connection posts totally corroded to the point where I just touched the plastic connector and the connector fell away from the board. Thank goodness that connector hadn't fallen off the board while flying. Anyway, that's why I now open up my radio and check every year.
Ikeep old jugs of glow fuel justfor engine cleaning. Irecently had quite at task freeing up a brand new O.S 1:20 Ft. It was so gummed up from setting all those years that it felt like things were welded together.After a couple days soaking, we were able to get the crank to turn over, but the bearing cages were still froze solid so the bearings were sliding, not rolling. It took two, serval hour long, sessions in the heated ultra-sonic cleaner in a beaker of glow fuel before the bearings finally loosened up. Once I got them running around the track OK, the next session broke loose all of the grease chunks and things were well.
I would pull the back plate and then the soak the engine. That allows the fuel to get in easier and do it's job, and you can also see the condition of the bearings that way.
Don
Don
MI
Portland, Oregon. Beautiful!
Just returned from 6 weeks along the Oregon coast, all 3 areas. Wow!
Anywho.....thanks for the tips. My wife and I are doing a lot of extended time travels all over this country, and I decided that I want to bring along a couple of smaller(for me) planes, set up to convert between ground, water and snow. Hand launch when desperate! So the 20-30 lb'rs stay at home and an ACE 4-60 and a 40 sized trainer type will join us in the toad trailer. Will use 4-stroke for both convenience of fuel support and noise. Pulling a Fox 40 out of the trainer and replacing with an OS 48. 4-60 has Saito 65. I have a JR PCM10 that I will setup for both planes. I'm staying with 72MHz, have a couple of transmitter modules for channel selection. Hope to come up with a scanner to check for clear channel.
MI
Campgems...I am removing the backplate, muffler, and valve cover. Anything else that looks like it will help get liquid into the motor. Thanks for the tip, I'll pay attention to those bearings
ORIGINAL: sdad
You visited at the perfect time! From mid July through September there's no better weather on the planet than the Pacific Northwest. We get more than our share of gray days in the Winter Spring and Fall which I suppose is why we're blessed with such perfect summer weather.
