Do i need to update my HFP-10?
CA
RE: Do i need to update my HFP-10?
The HFP-10 will still work for most of the settings with the newer servos, you just wont be able to change the resolution of the newer servos, the over load protection and you will be limited to how much travel you can set for the servos rotation. To increase the servos rotation angle more you need to be able to take the servo out of its high resolution setting and put it to normal.
