eclipse 7
i have a ultra stick 40 & 120 . i want to use the quad flaps. will the eclipse 7 do the crow function [ailerons up,flaps down,elevator down], elevator to flaps mixing, aileron to flap mixing and the regular flaps down? can i program them all at the same time on different switches or do i need to chose 1 ,2 or 3 of the most used functions & not use the others? thanks alot,
conk
conk
thanks for the reply mike. i don`t understand though. flaps down with one switch & ailerons up with another? does that mean that i can`t mix the ailerons with the flaps on another switch & use just flaps & use dual rates? i would like to do all of the above . is it all possible or do i need a radio with 8,9 or 10 channels ?
thanks again,
conk
thanks again,
conk
