5995TG Question
5995TG Question
Mike, I just received two new 5995TG servos. The package only contained a 1inch metal servo arm and a bottom plate for the servo. The bottom plate that is on the servo now has a threaded brass insert. What surprised me the most was the lack of grommets or sleeves to mount the servo as normal.
Is the bottom plate with the brass insert suppose to be change with the normal plate for RC usage? Where are the grommets?
Duane Cox
San Antonio Texas
Duane Cox
San Antonio Texas
My Feedback: (31)
RE: 5995TG Question
The 5995TG are not shipping with grommets and eyelets as these servos are designated and or offered for Robotic applications. However a grommet and eyelet package is available form Hitec Service for RC use.
The Robot bottom case cap can be removed and replaced with the included part if so desired, it is intended for RC applications.
