Cyrstals
Hey Guys, I know this question has been asked a hundred times but I can't seem to get a straight answer(one for a layman) that explains the difference between a dual conversion crystal and a single conversion. I am also in the dark about a high range crystal and a low range. Sorry to bother you but can someone give me the straight poop without all the tecknics.
They call me Crash Armstrong at the field.
CA
A dual conversion receiver had a second stage of filters in it to filter the signal. This means you would have a cleaner signal with less chance of interference.
The high band/ low band is something that Futaba uses to designate how their receivers are tuned. Low band would mean the receiver is tuned for channels 11-34 and high band is tuned for channels 35-60. This does not apply to Hitec receivers as our receivers are center tuned so you can use any channel crystal in the receiver.
Thanks Brendan: I think I finally got it. Even most of the guys in our club don't seem to know the answers or if they do, they won't tell. Thanks again!
