Profi 4000 mixers
Hi all,
Trying to set-up the mixers in my Profi 4000. The instruction booklet leaves much to be desired.
Here is what I need to do... Mix a small amount of elevator into rudder on my fixed wing so when I am in knife edge the airplane will not pitch to the belly. I am using 2 elevator servos and 1 rudder servo.
I have found both the servomix and multimix but don't know where to go from here.
Thanks again.
Tom...
Thanks again.
Tom...
CA
Check this site out for help on programming hints: http://www.rc-soar.com/multiplex/4000/4000.htm
