Amps through HPD-07RH?
How many amps may I run through this QPCM receiver without damaging it? Will I be able to use it on 6V with 6 x HS-5625 MG, 1 x HS-422 and 1 x HS-325HB without a powerbox or switch?
My Feedback: (31)
RE: Amps through HPD-07RH?
ORIGINAL: Vismund
The servo load you mention above is NO problem for HPD-07 RX.
Be sure and utilize HD quality connectors, wyes, switches and extensions with a single and or combined battery capacity of at least 2800mAh.
Make sure you have no binding at neutral and extreme travel arcs; this will keep the current consumption to minimum and prevent premature failure of your digital servos.
