Eclipse 7 QPCM( NO MORE problem)
Drains battery in off possition. Now it quite all together. I have not used it that much and battery seemed to be always low. Replaced battery with new 2500 when I got the radio to make sure I would have anough to make a few flights and it drained it , then shut off and will not turn on.
Larry
The battery checks OK out of the radio.
Larry
RE: Eclipse 7 QPCM problem
I would suggest you send it in to have it checked out.
Here's the info: http://www.robonova.com/manager/prod...end_prdSeqid=9
Mike.
Mike.
A BIG THANK YOU to The people at Hitec.
Talk about service this has to be a great turn around for my radio. Can't wait to try it out
I'm gone.
Larry K
Works great Thanks again
I'm gone.
Larry K
