Full charge li-ion
Full charge li-ion
I have read that you've said it's OK to use unregulated 7.4 battery on 7955. With a full charge my li-ion's have 8.4 volts and come down to 7.2 where I re-charge. Is that OK un-regulated on 7955's. Thanks
Bill
Bill
My Feedback: (99)
TN
RE: Full charge li-ion
Mike, So running unregulated lions with 7955's will not void the warranty or hurt these servos? When will Hitec post this on their website that it's OK to do this? Only asking because I'm loading out my AW YAK with nine 7955 servos and it would be awsome to not have to buy a regulator for them. Thanks for the info......Skip.
My Feedback: (15)
CA
Skip, I would like to know how your HS-7955TG'S are handling the 7.4v li-ion's un-regulated so far??? I would like to also use a full House in my AW 100cc Extra. Thanks!
Paul.
Paul.
Can try use AN 7806 being regulator,but must paralel in 4 pcs...output in 5,99 volts...i use 2 cells lippo batt 8,4 volts ..flight all day without change my RX batt n all servo in good work..
