Servo jitter
I can't figure this one out. My servo jitters back and forth when I turn the power on. I have a Futaba 9C and using a Futaba FP-R127DF receiver. I am also using Hitec HS5625MG servos. Every channel works great except the left aileron which is plugged into ch.6. I have two of the same receivers and both do the same thing. I tried the jittery servo in different channels to see if I get the same results, and I don't. It's quiet and works great. Other good servos plugged into ch.6 act the same, jittery. So do you think it's this receiver type, or a setting in the 9C I am overlooking?
ORIGINAL: Flyboy1958 I can't figure this one out. My servo jitters back and forth when I turn the power on. I have a Futaba 9C and using a Futaba FP-R127DF receiver. I am also using Hitec HS5625MG servos. Every channel works great except the left aileron which is plugged into ch.6. I have two of the same receivers and both do the same thing. I tried the jittery servo in different channels to see if I get the same results, and I don't. It's quiet and works great. Other good servos plugged into ch.6 act the same, jittery. So do you think it's this receiver type, or a setting in the 9C I am overlooking?
See also sub Section "Glitches & Jitter in Receiver, Servo & ESC - causes and cures " under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links</p>
Regards
Alan T.</p>
