What happens in 80 km/h
Got my new radio yesterday, the new and best aggressor crx from hitec. anyway i was going to try out the new ABS system, and it turned out that my truck was way too heavy for it to work properly. I was going in top speed, about 80 km/h when i see that i want make the turn. i then hit the brakes(which doesn't work) and BANG my car crashes into a steel thing . as i can see until now the only things that are broken are the radio bocks, one alu shock, a servo horn and some small plastic parts.
RE: What happens in 80 km/h
for example the initial breaking point could be 0.5 seconds on, then you set up the rest of the abs cycle off 0.3sec on 0.4sec off 0.3sec and so on. its trial and error setting it up so do it in a large area but eventually youll get it rught.
yes i can dissable it. i just think my 605bb is too weak and too slow. I was just so tired of my truck flipping over
if you r truck was flipping over the servo is obviously strong enough, just set up the duty cycle on the abs and then it will stop properly without flipping.
No no my truck was fliping over before the abs. but mbx5 do you use your abs what servo does you use. what is the speed and strength?
if ur truck is flipping over and you drive on-road take off the spacers at the top of eack shock
i did it and my truck neva flips during breaking or turning!!!
i already did it i can change my spings to some soft ones though, but i am using the dirt bonz and they got a really good grip compared to the stock ones, on road
SUCK POO
its always good to c a sick crash
[sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif]
FL
I use ABS with my PK3 and it works great. Sounds like if it didn't work very good then you don't have it dialed in correctly. I don't know about the aggressor but the PK3 has several settings with the ABS and can be tweaked for each application.
