Savage x ss problems
At full throttle the carve i the air filter does not completly open. only 1/2 of it opens!! dunno why?
some help please [sm=wink_smile.gif] thanks a lot.
AB, CANADA
RE: Savage x ss problems
i had this same problem with my savage x... took me awhile to figure out but all i did was shorten the throttle arm linkage by tightening it about 2 turns and it fixed the problem.
You will have to reset your throttle after doing this.
Also, make sure your radio EPA is adjusted so that the Savage linkages move through their full motions to operat the throttle. Be sure to set the EPA just to the right amount, not too much and not too little.
Aside what everyone else already said, this is all I can think of.
