Savage with Picco .28 clutch
MA
I just picked up a Picco P3 .28 with SG shaft, does anyone know if the stock flywheel and clutch will fit properly if I use a SG clutch nut ? I really don't want to cut the shaft to use the stock one piece clutch nut/shaft. It's a Savage .25 flywheel.
Thanks.
Thanks.
TX
RE: Savage with Picco .28 clutch
Correct me if I'm wrong but does the .25 not also have an SG shaft? If so, then yes, using the .25 flywheel will be fine, but I'd recomend upgrading to the 3 shoe.
NitroVette- Everything will fit perfectly fine, its a direct swap from the stock .25 engine- congrats on the monster engine purchase man. When the heck am I gonna see a vid of that Vette running!?
MMA- I think you got confused by the way Vet said "stock one piece clutch nut/shaft."- but all Savages from the 21 and up have been using 3-shoe clutches.
Tom.
Tom.
TX
Tom, sorry to tell you, but thats wrong, the [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDLF7&P=7]Savage .21[/link] did you use a 2 shoe flywheel/clutch, but yes, I was confused, the [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFXU6&P=7].25[/link] did come stock with a 3-shoe.
Oh damn, lol its been a while since that old bird has been out, can't believe I said that *scratches head*. Thanks for the correction lol[sm=spinnyeyes.gif].
MA
Thanks guys, I haven't pulled the clutch off the old motor yet and just wanted to know if I needed a SG nut without the CB pilot shaft. I hope to have the Vette out this spring, it's still pretty cold up here.
QC, CANADA
ORIGINAL: junior driver
how about the stock fly wheel and clutch shose of savage xss ? do they fit picco 28 ?
