Engine side thrust
Hi
Are people still mounting engines in IMAC models with right side thrust, or are you now setting engines at zero degrees right and using a throttle / rudder mix.
![](/forum/images/badges/premium_member.png)
My Feedback: (29)
Side thrust on both IMAC and pattern airplanes. I have in the past as a quick fix for models that didn’t have enough right thrust to set up a mix but had limited success with it. I currently have a new Edge 540 awaiting test flights. I will not be painting the cowl until the right thrust is set correctly. Right now it is set to 2.5 degrees. Running a 3W 106 with full length pipes and a 26x12 tri blade prop I suspect I will need to add more.
![](https://cimg1.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/3710528e_a2e9_4518_9db9_5f1618e98f20_dac3b0e09e4b09634eb69d6a7013100ec4754555.jpeg)
I always set few degree right site thrust in my giants, no matter if its scale or scratch built foamy. Currently fishing for a coaxial counter rotator to fit in my giant Bipe to see the effects.
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/same_size_but_55_lighter_3b41eafd745a67f75624c4868d22e4f6811b9150.jpg)
110/8S versus 360/12S Eflite power both with R side th.
![](https://cimg5.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/another_giant_morn_d16e24a29eff50c645f2ccbf379abd4e1a9d3271.jpg)
Giant 160/8S powered foamy designed by JF Jet Studio with R Th ready for coaxial to compare.
