p-60 glow plug error
HI,
I have a brand new p-60 with a kerosene ignitor. After the third successful start, it showed a glow plug error. I switched to propane start and installed a glow plug. It still shows the same error. I contacted jetcat and they asked me to send in the kerosene plug. They sent me a new kerosne ignitor. I installed on the turbine and still got the same error. I contacted them again and they asked me to send in the ecu in which i did. They tested the ecu and sent in a glow plug 3 cable wire in case it was the cause. I received the ecu and the cable, I installed them and still got the same error. I'm living in the United Arab Emirates. I wasted time and money to send in these items to jetcatusa with no use. Any help or idea from anyone would be appreciated.I thought the error might be in the turbine itself???...
![](/forum/images/badges/premium_member.png)
Hyman,
we buy a new P120, I have fear of problems, therefore, the remittance cost is very expensive!!!!!![
] I am waiting the reply that goes to give to you![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
good luck!!
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
good luck!!
