P-120 under cover gas Festo fitting sealing?
I removed the 3mm gas line Festo fitting from the brass tubing which is located under anodized cover of my P-120. I had impression that it was sealed by same kind of glue. Should I use same kind of sealer during reinserting ? If positive-what kind of sealer should I use?
regards
Marcin
regards
Marcin
