JetCat fuel pump question.....
hello all,
i found a used jetcat fuel pump in my parts stash today.....i tested it for a few seconds with a stock jetcat ECU 7.2 volt battery.....it operated fine.....
i'm also making a new fueling station for this year......
so the question is:.....can i use this fuel pump with the 7.2 volt battery?.....i don't know what the maximum sustained voltage the pump is rated for.....is 7.2 volts ok, or should i think about using a 6 volt battery to run the pump for fueling / defueling?
any thoughts?
thanks,
Rich
any thoughts?
thanks,
Rich
My Feedback: (10)
RE: JetCat fuel pump question.....
ORIGINAL: av8rk
hello all,
any thoughts?
thanks,
Rich
hello all,
any thoughts?
thanks,
Rich
I think 7.2 volts is OK but I would not expect long life from a used turbine pump pressed into refueling duty!
Hope that helps,
