6102 throttle mixing
TX
Danny,
I just recently got a twinstar. I also have a new xp 6102 radio, and was wondering if I could plug one engine servo into the throttle channel, the other into the AUX 1 channel, and then mix the two at 1:1. If so, would this allow me to adjust the endpoint travel of each servo individually, and electronically? Could I adjust the idle trim for each individually? would the throttle kill button still kill both engines?
2slow
2slow
RE: 6102 throttle mixing
Yes, you can do that, so the main throttle trim will work on both and so the throttle kill will work on both, set up the program mix in mix number 4. You can then use the flap rocker as a trim for the second engine as well.
