Sig 1/4 J3 Kit converted to PA-18 Super Cub (Build)
#127
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (129)
ORIGINAL: Cub Man
SunDevilPilot Love the tires in the photo above. I need a set of them that are about 8 to 9 inches.
There is a thread on that. About the only available source is from Bill Hempel. He has them for his big 50% Cubs. Kinda spendy though.
#131
![](/forum/images/badges/premium_member.png)
Turns out that I recently needed a set of giant "tundra tires" too on a low budget.
In my case, I used the inner tubes from hand truck tires with rims from laminated balsa and lite ply on the ends. The suggestion was to use a piece of PVC tubing for the wheels which would also work.
These came from the design of a Mud Duck, which you can find on RCU or at the Mud Duck web site.
#133
Finished a minor detail on the fuselage which I had been putting off. I was a little apprehensive about carving a recess into the lower rear of the fuselage for the tailwheel mount but it went off without a hitch. I changed the mount to a blind nut that I cut the barbs off and mounted inverted on the plywood plate. I just didn't like the square nuts that Sig gave for the mount. The fuselage cutout was done with a double flute straight cut bit on my route table. I just set the depth and mounted a stop to give me the proper cutout. Then, reluctantly, I ran the fuselage across the bit. The router made quick work of the job and the results were great. I was afraid of what the router may do the balsa (splinter it) but I found it cut it clean and smooth with no splintering. A recess was made for the blind on the fuselage.
I made my own ply plate out of a little better grade ply than stock.
SunDevilPilot
SunDevilPilot
#134
I received the 22X12E Mejzlik prop from Desert Aircraft and it looked a little large. Fortunately, with the 6" tires there is plenty of clearance between the prop and the ground when the plane is level. I'll just need to be careful with hard landings. I'm really happy with how the cub is looking to this point...
SunDevilPilot
SunDevilPilot
#135
My Feedback: (129)
That prop is huge for a Cub, considering my 108" Super Cub flys great on a 16". Can you go down a bit in size like 18 or 20" and run a lesser battery? I'm not into electrics and don't profess to know anything about them. Just seems like you will be spending a bunch of money on broken props.
#136
ORIGINAL: TripleDeucer
That prop is huge for a Cub, considering my 108'' Super Cub flys great on a 16''. Can you go down a bit in size like 18 or 20'' and run a lesser battery? I'm not into electrics and don't profess to know anything about them. Just seems like you will be spending a bunch of money on broken props.
Reference prop strikes. Hopefully three inches clearance is enough. I have a large gasser with a similar clearance and I have never had a prop strike (Except for when the landing gear failed during taxi). If needed I could go three bladed to reduce the diameter. For now we'll see what it does.
SunDevilPilot
#137
NC
Speaking of those batteries, how are you planning on doing battery changes? I saw a 1/4 scale cub that was converted to electric only to be later converted to gas because of the pain of taking the wing off to change batteries.
#139
ORIGINAL: AmishWarlord
SunDevilPilot
#140
My Feedback: (129)
Okay,like I said, I know nothing about electrics. Just seems to me that if you have less power with a smaller battery, you wouldn't load down the engine more with a bigger prop. Smaller motor? Anyway, you guys know what your doing so I'll just watch.
Battery changes should be no problem with the side door option that SDP already has built in.
#141
SunDevilPilot
#142
I won't deny the prop looks big.... However, I was looking at the previous photos and for some reason it looked really big. May have been the perspective of the photo. I am attaching a few with the cowl on and the tail feathers in place. A better sense of scale can be seen with those parts installed. Once the wings are built I think it will look really good.
SunDevilPilot
SunDevilPilot
#144
ORIGINAL: Cub Man
http://www.youtube.com/watch?v=F8lVdUhdJVE&sns=em
SunDevilPilot
#146
SunDevilPilot
#147
Work has started on the wings. I moved my building table into the house due to the heat in the garage. I'll tell you, the wife loves the new addition to the living room!
The photo shows the ribs dry fit to the bottom spars. Once it was together I decided I will duplicate rib W2 and place it about midway between the stock W2 and W1. This will allow me to have a rib in the area of the sheeting right at the location I plan on ending the inner edge of the flap. The inner sheeting will be modified to allow for the flap. I also adjusted the main spar slot on W2 rib to allow the wing to have no dihedral. From all the photos I have seen a Cub, and a Super Cub, have little to no dihedral. For some reason the Sig Cub calls for quite a bit. I may put a tiny amount but with the larger slot that can be done when the wings are fitted to the fuselage. The slot is more of a pass through than a structural element.
The wing design appears to be quite simple, time will tell.
(Keep in mind reference the photo. This was only a dry fit. The spar and ribs will be pinned tight to the board when I glue them in place. I will also protect the plans with some wax paper.)
SunDevilPilot
SunDevilPilot
#148
It looks a though you plan on building each wing panel over its own drawing. I did that with my Sig 1/4 clipped wing Cub. Much to my surprise, the result was that one panel was about 1/4" longer than the other.
I've heard of paper shrinking and expanding depending on humidity. However, when I actually measured the plan panels under identical weather conditions, they were different spans.
#149
NC
ORIGINAL: SunDevilPilot
Wow! Those are expensive. I would be quite unable to take a razor blade to them after spending nearly $1000.00 for a pair.
Yeah no kidding. I was thinking like $100 each. I can't imagine the most expensive item on my plane being the tires. Seriously though $1000 for tires for a RC model plane and they are not even the right scale!
#150
NC
ORIGINAL: do335a
It looks a though you plan on building each wing panel over its own drawing. I did that with my Sig 1/4 clipped wing Cub. Much to my surprise, the result was that one panel was about 1/4'' longer than the other.
