Carl Goldberg Ultimate 10-300 Brotherhood.
#376
ON, CANADA
ORIGINAL: Johnny_Zero
I have had 3 Goldberg Ultimates. None of them needed to have the hinge gaps sealed. All of them were powered with YS 120's.
Not all beasts are alike ! Some like to have hinge lines sealed. Something to think about. It was only a suggestion for those who don't know about flutter and just to keep in mind. A friend of mine bought a built kit (Ultimate) and has a Saito 150 (overkill), and so far he did not experience any flutter. He has 2-56 pushrods and mine has 4-40 pushrods. I did not use the hardware that came with this ARF, I upgraded everybit of hardware. Like I said this is a different beast, terrific to fly with no bad habits.
#378
ON, CANADA
Sorry I didn't mean to offend. I have just never seen a flutter problem on a Goldberg Ultimate.
#379
![](/forum/images/badges/trading_plus_member.png)
I seal hinges on everything, from my foamies to my giant scales, just in case.![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
A bit more progress. Have to harden the linkage points on the ailerons before they get covered and installed. Waiting on extensions and an A123 Racing 6.6v 2300 pack. I should get both this week. I gave up on the LiFePo4 from Hobby King as its been 6 weeks on backorder and I've waited long enough, lol.
#380
ON, CANADA
Revy..Nice work. Just a suggestion you might want to think about it. My CG Ultimate is the ARF Blue Hawk, to make it more visible during landing approach I added yellow strips to the wing's leading edge.
#383
![](/forum/images/badges/premium_member.png)
Nice ultimate you got there, hope I do as good a job on mine when I start it.
Got a question on the covering though, have you just used a sticky trim covering to add your detail on top of traditional iron on covering or is your detail ironed on over the base colour! The reason I ask is although I can get a perfect base cover I struggle to iron on any detail without it being a dogs dinner/full of bubbles.
Maybe should have started another thread.
#384
ORIGINAL: Revy
Thank-you. A clubmate expressed the same concern. I have been thinking of a solution that fits with the scheme somewhat.
I'm done the top.![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
I'm done the top.
#386
ON, CANADA
ORIGINAL: raydar
Go the Windex way. It will slide quite easily. You just have to make sure you don't spray too much. Use a credit card to squeege out the excess. Leave it overnight.
#387
ON, CANADA
Maybe......interplane struts and wheel pants done in red and white?
Here's a picture of my CG Ultimate 10-300 Blue Hawk with yellow covering on the wing's leading edge.
#388
ORIGINAL: Garthwood
ORIGINAL: raydar
The graphics are Ultra-cote. I did iron them on. Had a couple bubbles that got worked out after pokin' them. Trick is to be light with the iron trying not to press the covering through the balsa. I actually didn't know that Windex worked on that stuff too. I knew the Mono did, just didn't have any in those colors. Learnin' a ton with this build!
#389
TX
An updated members list:
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
Francisco Ortiz # 31
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
WarbirdAirRacer # 50
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
All numbers from here and on, are available.
New members, who want to join this great Brotherhood, please take the next number available (# 60 in example) or grab any number in advance of your choice.
Thanks.
#390
TX
ORIGINAL: Garthwood
If you would like to join to our Brotherhood you will be # 60
About fluttering:
I have seen a CG Ultimate with a fluttering problem on one elevator, the pilot was very skilled, even though, he was in problems trying to bring the bipe down, what we found is that two ca hinges were about to be pulled out. While the problem could be only on the assembly process, (because I have not see any other fluttering problem), it is a good idea to seal the hinge line, it has also other benefits.
I did seal the control surfaces on mine and have have zero problems, (my engine is not as powerful as a YS 120, but I feel in the comfortable side anyway).
Alfred.
#394
ON, CANADA
ORIGINAL: alfredbmor
Garthwood:
About fluttering:
Alfred.
ORIGINAL: Garthwood
About fluttering:
Alfred.
Thank you also for the offer of the Ultimate Brotherhood. I accept the Ultimate Brotherhood #60, that's a nice number.
I have zero problems since then. I learned from experienced pilots who fly big gassers.
#395
ON, CANADA
Garthwood:
About fluttering:
Alfred.
ORIGINAL: Garthwood
About fluttering:
Alfred.
Alfred........................oops........I think we got a conflict regarding the Brotherhood #60 you passed to me. What next ?
Ultimate Brotherhood # 60
#396
TX
I see the issue here, first of all, let me give to you both a great welcome to our Brotherhood (no matter what your number is), the fact here is to find interestin information as well as share some knowledge relating our CG Ultimate biplanes.
I believe, that the best way to solve this issue (as a Brotherhood), i tol try to let you both (Garthwood an Johnny Zero) to chat and come with a proposal to solve the issue.
If it is not have been taken in a short period of time, I, then, will submit for your consideration a Salomonic solution.
Either way, please consider your self, as members of our community with equal rights and obligations, please have fun.
Alfred.
Alfred.
#397
ON, CANADA
Alfred.
Alfred.
Charles.
Ultimate Brotherhood # 61
#400
TX
Updated members list:
maukaonyx # 01
JohnMcGowan # 02
Cub Man # 03
DanS # 04
u2builder # 05
CRJDriver # 06
alfredbmor # 07
captinjohn # 08
yekots # 09
everwood # 10
JNorton # 11
Tailskid # 12
Crash Campbell # 13
frequent flyer # 14
daveopam # 15
VCScott # 16
PropWash # 17
eaticus # 18
mistermnkim # 19
Zebra One # 20
JimboGreek # 21
tony 0707 # 22
pushinoldrc # 23
bigal126 # 24
Steve Campbell # 25
raubold # 26
Revy # 27
twn # 28
vt-flier # 29
rk2648 # 30
JohnB 96041 # 32
David Agar # 33
IMaflyer # 34
Reefrus # 35
Jduran157 # 36
Bipeguy03 # 37
SRQFlyer # 38
Charlie111 # 39
Flygilmore # 40
Falling leaf # 41
ericzombie # 42
Pacomb # 43
Atlanta 60 # 44
Gunneredwards # 45
braddock VC # 46
Cyberfyn # 47
Mrshea # 48
Peternj # 49
Abbott915 # 51
ArcticCatRider # 52
THEJADEGROUP # 53
Jjoos99 # 54
MajorTomski # 55
Twin Flyer # 56
72 #57
George Waldrop #58
TripleDeucer # 59
Johnny Zero # 60
Garthwood # 61
Available # 62
Available # 63
Available # 64
Available # 65
Available # 66
Available # 67
Available # 68
Available # 69
Eddie James # 70
CanDo # 71
New members, who want to join this great Brotherhood, please take the next number available (# 62 or # 72 as an example) or grab any number in advance of your choice.
Just a note: As a remainder, if any of you wish to belong to our Brotherhood, do not hesitate and take the next number, if, as it has happened before, other member took it, please have a little chat to get in accordance with numbers, or just take the next number available.
Thanks.
