reverse crutch?
reverse crutch?
i have seen this mentioned several times and i cant seem to find a definitive explanation of it. i think that its just a mirror version of the stock crutch but i could be wrong.
also, i have seen several mentions to changing the stock engine to something more powerful/durable. i think that a .12 car/buggy engine would be perfect but i dont see how i would make the clutch for it.
does anyone have any kind of writeup they may have done for a buggy/truck engine conversion? i did alot of searching and came up empty handed
RE: reverse crutch?
Well I guess you could always make another crutch and make it mirrored, is it to clear the exhaust from the spurgear ?
I just flipped the engine to the other side, you have to come up with a different fueltank assembly though.
Yes the .12 car engine have been on many peoples lips.. including mine
What you need is to get a carengine preferable with a strapstarter since it will be very hard to start the engine with a starter unless you mill a new starting cone.
On that carengine you need to attach a Team associates clutchbell, this clutchbell have the same pitch on the teeth as the LMH clutchbell. which I think is 32 degree.
Attach the engine to the heli and fly... don't use full throttle !!
//Peter
Search this forum for
cv 12 mounted on lmh 117
//Peter
//Peter
//Peter
