LST HI low selector causing it to jum,p out of gear
My Feedback: (28)
Please help Do any of you lst fans out there have the answer? it will drive great for a minute or 2 then it slips out of gear and then you can turn the hi lo selector knob a little but it wont stay I have just bought the truck used and have no idea what is going on this is my first lst and the 16 th nitro to enter my colection thanks for any help
jason o
jason o
My Feedback: (-1)
RE: LST HI low selector causing it to jum,p out of gear
Jason, a quick solution is to buy the Forward Only conversion. It will solve you problem, and it has other benefits, such as removing most of the gears in the tranny, which lowers rolling resistance, and allows for faster acceleration, as well as higher top speeds
ON, CANADA
The Hi/Low set in a Little groove(it shouldn't be able to pop out) , Are you sure it's Not the Rev Servo Moving letting it slip into what feels like neutral ? You can adjust the EPA for the Auxiliary Channel,So it Holds it in-Gear..... Or it could be the OWB in the 2-speed Slipping?
mine has been doing this too, but i thought it was my one way bearing causing it. i'm going to look it over as i didn't spend much time looking for the culprit.
does it do it from landing off big jumps?the problem is the EPA u need to put more epa on the gear selector servo,its starts to pop into a false neutral if u dont
yeah that ALSO was happening to mine, the FWD only kit solve it all, and make my truck ligther and more responsive..
are you sure it is not the reverse.my lst2 was jumping out of gear when you turned to the right.alli had to do was reset my radio and change some programing in the radio and it fixed it
Give us more input, did you mention the hi-lo selector, probably it goes to neutral as the top selector knob is broken, or same as the other guys said, the reverse goes to neutral?
