4 OMG ST-32CF IP67 Waterproof High Torque Servos
4 OMG ST-32CF IP67 Waterproof High Torque Servo's $75 they are less than 1?month old mounted but never used I abandoned the project.
Feature:
Specification:
Feature:
- Recommended for Rock Crawler and Off-road Racing
- IP67 Waterproof
- High performance, high torque and hight quality standard size middle aluminum case coreless digital servo
- Aluminum middle case helps dissipate heat
- Digital precision provides great accuracy and performance
- Compatible with all types of Radio system
Specification:
- Type: Digital
- Operating Voltage Range: 6 - 8.4Volts DC
- Speed (s/60°@6V/7.4V/8.4V): 0.092 / 0.089 /0.083
- Torque kg./cm. (6V/7.4V/8.4V): 27 / 29 / 32
- Size : 40 x 20 x 38mm
- Weight: 77g
- Motor Type: Coreless motor
- Control System: +Pulse Width Control 1500µsec Neutral
- Required Pulse: 3-5 Volt Peak to Peak Square Wave
- Shaft: 25T
- Gear: Metal
