35cc gasser question
how many flips of the prop should my 35cc gasser need to start it after it get's warmed up (monitor that is a question ),,,
mine now takes 2 to 5 flips and it's still a little burbling rich on the low end (in flight), so I think it may get better once I get it set right, I'm very happy with the performance of the 5 cell ignition pack..
Jim
Jim
RE: 35cc gasser question
Depending on state of engine, idle carb tune, hot cold, choked or not, it may take anywhere from 1-10 flips, so you are doing OK.
A slightly rich idle setting will make a better starting engine.
