mvvs 1.6
My Feedback: (109)
mvvs 1.6
I have been having trouble starting my 1.6 as well as consistent running -engine dies, I have found the case is cracked at carb mount flange as well as o-ring is split, my question-where do I buy a replacement case(I see that horizon evo 1.6 case appears the same) -and if replacing the case-how much work is involved or do I need to send it in to service center-thanks jmc
RE: mvvs 1.6
Jim,
You can ask any of the MVVS dealers here; myself, PĂ©, or David.
Some may have it in stock and others might need to order it in for you, but you will pay less than the Evo price anyway.
RE: mvvs 1.6
If you want to try the "penny-tech" repair, you could fill the crack with JB weld and install a new o-ring. I've had customers do that after thier engine has a dirt-nap!
My Feedback: (109)
RE: mvvs 1.6
Yes I have to admit, it took a little "POWER DIRT-NAP" I pancaked a GP chipmunk in the dirt and the engine is mounted inverted-the velocity stack had enough dirt for a garden-lodge inside. I think that may have been the problem to cause the crack-although it is very small, right at the point where the case meets at the top of the carb flange , if this make sense-everyone has been very helpful here and I appreciate it-I wonder how much a new case would be -thanks jim
