MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 45 IRS Idle SLow to Return to correct setting
Old 07-20-2008, 06:13 AM
Default MVVS 45 IRS Idle SLow to Return to correct setting
I have a new MVVS 45 which I've just completed running in (well I've finished the bottle of run-in oil that came with the engine mixing as per instructions and am now running specified mobil oil). After running at high throttle for approx 30 seconds or more, when returning to idle, the engine remains at a high idle and will only return to the correct idle after approx 30 seconds. (This happened both with the run-in fuel and current fuel). I have checked the throttle linkage for any slop (which there is none) and am using a digital servo so I don't believe that this is causing the problem with the idle. This is my first gasser engine, so any advice will be welcome.
Old 07-20-2008, 01:59 PM
Default RE: MVVS 45 IRS Idle SLow to Return to correct setting
you are running the idle too lean. Richen it up a bit, and readjust idle rpm with throttle servo.
Old 07-30-2008, 12:07 PM
BaldEagel's Avatar
Pe
Ten days gone past and no one has said thank you, so accept my thanks anyway.
Mike
Old 07-31-2008, 07:53 AM
I am not sure if Barney's problem is solved. Why would you say thank you on his behalf? Still feeling guilty of sending those poor blokes down under in chains eh?
Old 07-31-2008, 08:09 AM
BaldEagel's Avatar
Could be, very well could be. LOL
Mike
Old 07-31-2008, 04:13 PM
Hey Barney, where are you?
Old 07-31-2008, 06:37 PM
Hi Guys,
I'm back on-line at last. I still haven't solved my problem due to illness and at this point in time will not be able to fly for at least another 2 to 4 weeks.
Thanks for your responses. I'll let you know how I go when I am able to get back my local field.
(BaldEagle: Thanks for your reply in my absence. I bet you're the guy at the local field helping people learn to fly and solving their issues. Its good to have people like you involved in our hobby/sport!!!)
Old 08-01-2008, 06:01 AM
BaldEagel's Avatar
Barney
Hope you get well soon and back to flying, your description of me is about right, I try to help when I can.
Mike
Old 08-01-2008, 05:46 PM
Today we had a similar issue with a Zenoah engine. It was a bear to start, until the idle was richened. As a consequence, the engine settled into a nice put-put idle faster. Before that, it tended to linger at slightly higher rpm before settling down.
Old 08-25-2008, 06:49 AM
Pe, Mike,
Thanks for your help and your well wishes. First day back at the field and the problem is fixed. It was just as you said, the idle was too lean.
Thanks Again!!!
Barney
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
