GT33 big end bearing replacing
Hello OS lovers..
I need to replace the big end bearing on GT 33 gasoline because crashed and drowned in a swamp during a week, I would like to see, cleaning when necessary to replace all the bearings but hard opening pin bearing is retained by some sort of stepped pin that is fitted into crankpin. Anyone know how to remove this pin, is it pull out, screwed out?
regards
Kartika
regards
Kartika
TX
Thanks for the tips. Got going on tearing down my engine again. I've got the screw off and the liner out, but how do I get the rod off of the crank pin? There isn't enough lateral play to slide the conrod more than 1/3 off of the crank pin. What am I missing?
Thanks!
Thanks!
You will need to remove the piston from the connecting rod, first. You'll need some snap-ring pliers, and you may need to grind the tips down to fit into the snap ring. Then, you may also need a screw extractor to grip the wrist pin and pull it out. Once the piston's been removed, it will take some play and wiggling to get the connecting rod off of the crankpin.
