46FX piston/liner
Nope...
But the ASP/Magnum 46 2-stroke piston/liner set is a direct drop in fit for the OS FX46 and FXi 46.
With better performance to boot.
If you can find one, because those engines are all discontinued. But with some searching and a bit of patience, sometimes you can find some NOS.
Curious, once you suffer the OS nickel failure, why you'd ever go back to another OS engine? AX has the same problem. How many short lived engines does it take to abandon a poorly made engine simply because it's easier to tune? The OS Surpass engines are heavy bricks compared to a Saito, the OS nickel junk lasts 1/3 the life of a quality German/Japan made engine. Only people my fathers age would agree these days. Most never owned an Enya, Webra, Rossi, or Super Tigre in their life.
The chance of finding an ASP piston/liner for a decent price, you could just get a lifetime runner like Enya, Webra, Rossi, or Super Tigre. They tune well for me, they're just different. I've seen locals suffer the same demise with the AX .46 and the AX .65 with peeled liners, and with fewer fuel choices these days it doesn't give an active flier room to experiment between castor and synthetic fuel. If search worked on this site, I'm I could find some history on this topic.
Some believe it's a repetitious lean run engine (abuse), or a poor choice in fuel, but the nature of a 2 stroke glow engine is bound to run lean at times, sooner or later. Your engine shouldn't self destruct because of a few lean runs, I always thought ABC was more forgiving than ringed engines if you had a lean run? Just one of those things that make you wonder...
Because i like them from an engineering (evolution) point of view and variety, rarely run them. People like junk cars and buy them. no diff really.
And every once in a while, those piston/liner sets also turn up new. That's how I got 2 of them a while back. New and unused. But if you can find an ASP 46, chances are you can pick it up for 10 to 20 bucks with a piston and liner in good condition.
I converted mine (and a few customer engines) to gasoline with the ASP piston liner set.
As they come, I think it is one of the nicest running OS engines.
Improper plating process. Nickel doesn’t stick to brass very well if the plating process is t done correctly. When done correctly, it won’t peel or flake off. Also, if the nickel plating layer is very thin, it can cause adhesion problems as well. Look at a Thunder Tiger ABN liner next to an OS ABN liner and you’ll easily see the difference. The plating layer on TT liners is thicker. TT liners don’t peel either.
For around $100, you can find a NIB SuperTigre .45 that will be stellar right from the box. If you need to use gobs of nitro, add a head shim to raise the head a couple thou. Nice running engines that last forever and don’t need nitro to run well (though 5% adds a little kick). With a flat spraybar swap, they run within 1k RPM of a Jett .45 on smaller props.
Fortunately, so far, none of my OS engines had peeled up yet, so over time I made the transition to anything else but OS.
I picked up two Super Tigre G .40 engines for $30 a piece, and when I picked them up, he had a new in box Super Tigre .51 ringed engine for just $60 more.
All should perform better than any of the OS versions more reliably.
Meanwhile any used OS goes for $60 pretty easily, breaking even for new replacing used, since I haven't seen one ASP liner for sale in a couple of years. Anyone who can find this thread who who can show me one ASP liner for $10 - $20 anywhere, I'd buy it.
But I have bought at least 2 damaged ASP 46es for 10~20 bucks, gotten one for free and another two undamaged ones for 25 or so. All had their P/L set in good condition.
Engines are dirt cheap nowadays, but I have not found the ST 45~5 class that cheap. what I see is all in the 75 bucks range.
Strangely enough I actually DID get a very clean G2300 for free. Owner wanted to get rid of it because those things guzzle fuel and he was fed up with that...
NY
I'm thinking about getting my old OS FX liner that is peeling, re Nickle plated. I have a shop down the block from me and thinking of getting a price for them.
I realize the piston will still be old but at least the liner will not be peeling anymore.
Has anyone had this done?
That shop would be hard pressed to replate to the correct thickness, as the tolerance needed is AFAIK not freely available information.
But IF they can, and if you know the tolerance, they can of course also adapt the liner to that old piston, me thinks.
In any case I have never heard of anyone replating Nickelcoated OS liners.
