OS 40 LA Airbleed setting
RE: OS 40 LA Airbleed setting
Luftman,
You don't set the airbleed screw on the O.S. Max .40 LA engine by number of turns. You look into the airbleed hole and set the screw so that it blocks it halfway. That't the starting position. Turn the screw in to richen the idle (closes the hole). Turn it out to lean the idle (opens the hole).
WI
Oh, thanks, I just thought there might be a factory setting to achive a precise "middle". I'm not really having any problems just wanted to know for future reference, if theres a problem to be had it will be mine .
Thanks alot
Thanks alot
