FS-40 Surpass FS-40S
Are the FS-40 Surpass and current FS-40S the same engines?
I have an FS-40 Surpass I bought around 1991 or so. There is no part number anywhere on the box or on any of the instruction sheets. The instructions are copyrighted 1987 and include the FS-20 if that helps.
I am wondering if the engine has undergone any changes or if all current parts are interchangeable as I may need a new piston/ring/sleeve (compression seems soft).
I can scan the original boxtop and instruction sheet for identification if that's necessary.
David
David
