OS 52 HEADGASKET?
![](/forum/images/badges/premium_vendor.png)
Very likely, the gasket is there. If you look carefully, you'll see that the gasket is very close-fitting inside the groove in the cylinder head. If you use a very sharp #11 blade's tip, or a very sharp needle, you can get it out. We've NEVER seen an O.S. engine come from the factory without the gasket....and that's after nearly 30 years of O.S. service!
