120 AX remote needle valve
Dear Bax,
I would like to utilize a needle valve attached to the fire wall, instead of the integral valve on the front of my 120 AX 2 stroke. Will this work and is there an OS valve assembly that I can utilize. I have a spare remote valve from a 91 FX, if they are compatible. Also, can I leave the existing valve 5 to 8 turns open instead of removing it, or will the existing needle entry hole need to be plugged? Thanks in advance for your support.
![](/forum/images/badges/premium_vendor.png)
You can use almost any needle valve assembly as a remote valve. Just set the main needle several turns open and use the remote assembly. Here is the O.S. remote needle for their large engines:
OSMG7258 28282000 REMOTE NDL ASSY #9B US$42.99
These parts can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
