THE LOUNGE 2
RE: THE LOUNGE 2
You usually only need to set up the profile once... what charger do you have right now?!
ORIGINAL: Longhair
Is this a good charger: http://www.graupner.de/fileadmin/dow...24120_6415.pdf
I want something that I can just plug in and not have to worry about setting the mAh everytime.
RE: THE LOUNGE 2
ORIGINAL: Lunchboxer
ORIGINAL: Longhair
It is a cheaper version of it that doesn't have any memory settings. I figure that since the number of different batteries are accumulating, I better play it safe and go with something that is totally plug & charge instead of plug & boom [X(]
RE: THE LOUNGE 2
well i'm home from the hospital! never letting myself go that far again! ugh... i kept hoping i'd get better on my own when it fact i just kept getting worse. but at least i had a prize to come home to!
the box was a little battered, rural mail delivery can be a brutal business "car country" is written on the box, and that's no lie; they probably threw it in a Subaru mailwagon (Japanese-spec plain vanilla Legacy with right hand drive) and bounced it along miles of crappy roads to get it here. [&:] however thanks to good packaging everything arrived unbroken!
pictured along with the amazing TB-02 are the LB-exclusive bonuses: two hobbico standard servos, Tamiya brand threadlock, two silvercans, Courage wheels, body foams and extra hardware bits, and the same Duratrax body scissors i've been eyeballing for months now. i'm not kidding when i say that these extras tripled the amount of non-kit RC bits that i have! thanks LB!
not sure when i'll start the build, as i wanted to do the body first since it's the hardest part (for me) but we'll see. i might just do what i did for the Brat and spray in the garage, then move it in to dry in the house.
anyone have any painting/body tips? i might head over to the painting and detailing forum and check that out. do you guys paint and then trim the body, or trim then paint? i've seen it done both ways so i don't know.
Edit: forgot to post the pics... lol!
RE: THE LOUNGE 2
LOL, re-re will do wonder to the value of the original.. hee... (in a bad way..)
That $305 price tag is gonna be hard to swallow now.. unless you are a hardcore collector!! (not me!!)
ORIGINAL: Longhair
$195 and I have to wait until April [:@]
Ebay now for US $305.00 (and counting)
RE: THE LOUNGE 2
ORIGINAL: Longhair
http://www.graupner.de/fileadmin/dow...ungen/6410.pdf
ORIGINAL: Longhair
that charger is TURD, spend the money on a decent charger and batteries, and your car will be amazing, it drives so much better with decent batteries, charged properly than with crappy batteries and a crappy charger. TRUST ME on this
RE: THE LOUNGE 2
ORIGINAL: mechanizeddeath
im no expert, but it looks like you posted the same pics 2 times. we will let you off, after being in hospital for a few days lol
RE: THE LOUNGE 2
Very cheap for $135, ha!
Anyway, get well soon, mechanizeddeath!! Then I expect to see the TB-02 built up!!
I am sure TEX will be finishing that up in no time, ha ha ha ha!!
RE: THE LOUNGE 2
ORIGINAL: rcluke
DONT !!!,
ORIGINAL: Longhair
ORIGINAL: Longhair
The one I am using now (10) or the first one I was looking at (15) is a turd?
What is a good charger that would work for both Ni.. & Li.. ?
RE: THE LOUNGE 2
ORIGINAL: Longhair
ORIGINAL: rcluke
DONT !!!,
ORIGINAL: Longhair
ORIGINAL: Longhair
RE: THE LOUNGE 2
I like to trim the body first, and them paint so I don't scratch up the paint when I am ready to trim. People have different logics for this is all depends on the person.
I like to clean the inside of the shell with alcohol, most people use dish detergent and a scotch pad to scuff it up a bit. Then just apply several light coats of paint, start with the darker colors if using more than one color.
Edit, that was in response to mechanized's question
RE: THE LOUNGE 2
Pajero $195 available in April!
http://www3.towerhobbies.com/cgi-bin...?&I=LXUGV4&P=7
RE: THE LOUNGE 2
Cut the body holes first. Mask the windows and use 1500 grit sand paper to lightly scratch the inside. Don't sand any parts you want to leave clear. Wash with dawn and warm water. Then just spray away with light coats. This is the key and allow some time to dry between coats. I would do 2 coats of whatever color you choose and a backcoat (usually white, but this depend on the paint used.) As for trimming, I like trimming the body first but leaving the trim til last has an advantage, you can just set the body down and let it dry on its own without fear of it flipping over. Lastly remove the film and apply decals. Then spray an clearcoat over the deacals so they don't lift over time. This also hides the edge of decals.
RE: THE LOUNGE 2
Let's see some pics, man!!
1/9th has to be huge, ha!!!
RE: THE LOUNGE 2
ORIGINAL: secretsg
Since you're in Europe. I'd get the LRP pulsar3. A little pricy but worth it. I think it has the best nimh and nicd charging software I've used so far. Does 3 cell lipo and unless you are flying you don't need more.
ORIGINAL: Longhair
ORIGINAL: rcluke
DONT !!!,
ORIGINAL: Longhair
ORIGINAL: Longhair
RE: THE LOUNGE 2
Is it hobby grade? I'd guess so, right?!
50 lbs.. LOL!! That's hard to carry around!!
ORIGINAL: secretsg
Size prospective. It's the volume of about 4 bruisers. Weighs about 50lbs? It uses a 7aH 12v leadacid cell. I love it but can't use it anywhere but right outside my house. []
RE: THE LOUNGE 2
Fire Dragon available for order from Tower:
$145!
I kind of like the look... old school futurastic?! ha!
http://www3.towerhobbies.com/cgi-bin...?&I=LXTRN5&P=7
$145!
Bruiser sold for the asking price of 1k. My stuff is usually not cheap but not outrageous either. Actually come to think of it the time spent on restoring this makes it really cheap.
RE: THE LOUNGE 2
thanks for the painting tips! overall the body appars to be a much simpler affair than the Brat, with that body i was supposed to use 3 colors, silver and black for the bumpers and trim, plus the chosen body color. i got frustrated and ended up with an all black (and now yellow!) job. looks like this body only needs some black at the rear, the rest is done with decals. and even the decals are fewer, thanks to the lack of full body Subaru stripes. [&:]
i've never heard of the clearcoat over decals trick, but it makes sense. argh, i should have asked this question before i went to the LHS for paint a few days ago! also i think too many coats may have been the problem with my Brat, i bet i put at least 6-8 coats on there and i think the resulting shell of paint was just too thick to flex with the body, especially with all the snow bashing i was doing.
i'm a little bummed, looks like i won't be able to use the Courage wheels with the Porsche body, as the offset is off by 2. [:@] i guess i could still use them but it would end up looking a little weird and probably rub. but on the plus side, i now have a set of street wheels for the Brat. well, once i get some rubber and the adapters!
and yeah i posted the pictures twice. hit cancel on accident and didn't check to see if they'd uploaded anyway. lol!
RE: THE LOUNGE 2
ORIGINAL: secretsg
http://www.foxflier.com/abrams/index.htm
RE: THE LOUNGE 2
RE: THE LOUNGE 2
It doesn't help that I don't really know much about chargers.
Charge is the only thing I know about them. When it comes to discharging, capacity measurement, battery maintenance and balancing I am in the dark.
