mini max equipment help
i recently got a mini-max. i have a flash 5x already.
what i need for my mini max is everything. (esc, battery, receiver and servos.)
my question is, how much should i spend on all thsoe items? are there any package deals?
also, if i wanted to upgrade to a slow stick or crazy max in the future, can any of those parts double for both the mini max and the future plane?
please help.
thanks
please help.
thanks
TN
You can get a GWS, Hitec Feather or FMA micro flight pack for about $85. That will give you your Pico servos, micro receiver, a small ESC (try to get at least 5A) and a fairly useless battery! Some distributors allow you to "build your own flight pack" so you get some choice. You'll do well to get better batteries and later on, for a Slow Stick, you'll need to upgrade your ESC to something rated for ~10A (a Castle Creations Pixie 20P is relatively costly but will serve you well for many later aircraft).
Cheers, Phil
Cheers, Phil
I got the whole GWS radio,rx,pico servo (2), 5 amp esc, and the useless 150Mah battery for 125, and the flight pak alone is $75-85 minus tx,rx, and I swap out between several planes with them, have seen the radio alone for $25.....Rog,,check out horizon hobby
