1300 Data Terminal
1300 Data Terminal
Hi, I acquired a PST 1300 and am looking for a data terminal for it. Can anyone tell me where I can purchase one, or does anyone have one that they would like to sell ?TIA
RE: 1300 Data Terminal
If you can't find one stateside, let me know. I have several, some redundant, as I have changed one ECU to Xicoy. (merely for evaluation as the 4 TEMS ECUs I have are still working perfectly.
The 1300 is a superb engine, I have two (and 2 600s) which have been faultless.
Regards,
David gladwin.
Regards,
David gladwin.
Hi Dave, found out from PST that the ECU is a TEMS and the supplier (GD Hobbies) is no longer around ? Anyways, I have talked with several contacts and PST dealers here in the states and have given up finding a GDT for it. If you have one available, I would be happy to hear back from you as well as what the cost would be. As far as I know the engine is in great shape and has not been run very much.</p>
I look forward to your reply and thank you in advance for your help.</p>
</p>
Doug Ives</p>
