moki 180
moki 180
I've got a friend here in Fresno that just this weekend took his Lanier Cap(80") on it's maiden flight. He put a G-62 in his, and it's out of sight here, literally. Totally unlimited everything.
I own a Moki 180 myself, and have that in a Goldberg Sukhoi, and in this plane, this is one potent set-up, and am very aware of the potential it has in the right plane.
What I've seen in my friends assembly of the Lanier though, is it starts out as a heavier airframe. Hence the reason he went for the Zenoah(of which he upgraded inginition too).
Also, I'm building(almost complete) a Midwest 80" Extra, and the prototype and plans call for the 180Moki. Although I don't think I would go with it in this plane, at least for what I want. I went gas..BME50 here.
To answer your question, from what I've seen and experienced, the Lanier Cap would be vertically challenged, as well as challenged in other areas of performance, and with it being an unlimited class plane, I would NOT recomend this set-up for all out performance. I'm not saying it would be a slug, just that there are better combos that would do a better job overall. Also I'm not knocking the Cap, or the Moki...quite the contrary...each is in it's own class though in my opinion.
Matter of fact....I've got the Hanger9 Edge just waiting for my Moki to come out of my Sukhoi. The Hanger9 Edge is a wee bit smaller then the Lanier, in most dimensions, and a better match overall. At least in my opinion,,,I hope anyways. All in time though, I can only work on 3 projects at once anymore. Hope this helps, and good luck.
